The operators of the Safety Tool are like subroutines or functions in a programming language: they yield results which may be further used to produce some new results, etc.
Table 2: List of arithmetic operators (in order of decreasing precedence), arithmetic arguments, arithmetic result.
Name
power
unary
multiplication
division
modulo (integer arguments)
addition
subtraction
Table 3: List of comparison operators (in order of decreasing precedence), arithmetic arguments, logical result.
Name
greater than
less than
greater or equal than
less or equal than
equal to
not equal to (C style)
not equal to (PASCAL style)
Table 4: List of logical operators (in order of decreasing precedence), logical arguments, logical result.
Name
logical AND
logical OR
Table 5: List of predefined mathematical functions (floating point or integer argument, floating point result).
Name
sin
sine
cos
cosine
tan
tangent
asin
arc sine
acos
arc cosine
atan
arc tangent
ln
natural logarithm
log
base 10 logarithm
exp
exponent ( power argument)
sqrt
square root
abs
absolute value
cbrt
cubic root
sinh
hyperbolic sine
cosh
hyperbolic cosine
tanh
hyperbolic tangent
asinh
inverse hyperbolic sine
acosh
inverse hyperbolic cosine
atanh
inverse hyperbolic tangent
As was stated at the beginning of the paragraph devoted to the tool's command language, the actions that may be applied to an object depend on this object's type. That is why the existing operators will be listed together with their argument lists and result types.
The simplest operators, acting on scalar type objects are listed in Tables 2 through 5.
There are two categories of operations: operators and instructions. The first ones yield a result computed using their operands. The second ones have a global action (such as output) or modify (some of) their operands.
Finally, some operators (or instructions) can have several syntaxes. The operation to be executed is deduced in such a case from the type and the number of operands. This note applies to arithmetic operators (number
number, number
vector) and to complex operators as well (for example, the NEW_LINE Operator).
See the Batch Language Reference Manual for the description of the syntax of all operators and instructions.
