The Tuning Set Manager is invoked by clicking the icon, which opens the Manage Tuning Set dialog. This dialog allows you to create standard tuning sets that can be used in the Analysis Manager for automatically setting up quick modification runs in NVH analysis.
To add tuning sets, click the icon, which opens the Define Tuning Set dialog, and enter a tuning set name. To edit a tuning set, select a tuning set and click the
icon, which opens the Define Tuning Set dialog, and edit the appropriate fields. To delete a tuning set, select the tuning set and click the
icon. Tuning sets can be reviewed by clicking the
icon.
To create a new tuning part, click the icon in the Define Tuning Set dialog. Enter a tuning part name and select a tuning type.
Different types of available tuning parts are shown in picture below.
• | Bush Part: Creates spring element between selected nodes |
• | Mass Damper: Creates a concentrated mass element at the selected node |
• | Tuned Mass Damper: Creates a tuned mass damped with mass and spring element |
• | Beam Part: Creates a beam element between selected nodes |
• | Rigid Part: Creates a rigid element between selected nodes |
There is an option available in the Analysis Manager to activate/deactivate the use of tunings for quick modification studies.
