Engineering Solutions
Tools Menu
Tools Menu
Tools Menu
The following features are available in the Tools menu:
Auto-Contact
Quickly and easily create one or more contact interfaces at once between several parts of your model. This tool is only available in NVH when the Altair OptiStruct and Nastran solvers are loaded.
Blocks
Create and modify a block entity.
Card Editor
Select the entities that are viewed in the card image subpanel.
Component Table
Displays components and their associated attributes in an interactive table.
Create Cards
Displays a list of all available cards to create within the select user profile.
Count
Obtain a count of all the entities in your database.
Delete
Delete data from a model database, preview and delete empty collectors and preview and delete unused property collectors, material collectors, or curves.
Edit
Modify existing entities using the Entity Sets, Blocks, Tags and Titles Update subpanels.
Fatigue Process
Create or open a fatigue analysis setup process.
Frequency Response Process
Set of process templates that use generic engineering data to automatically create frequency response analysis loadcases and associated solver cards.
ID-Manager
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include file in relation to the full model in order to avoid ID duplication.
Load Collector Table
Review and edit Altair OptiStruct load collectors.
Load Step browser
Create, manage and display loadsteps (sub-cases) and the associated control cards
Mass Trimming
Create, define, and realize mass entities.
Material Table
Review and edit Altair OptiStruct materials
Matrix browser
Explore Altair HyperMesh and Altair HyperView data entities and export the entities to external files for further analysis.
Model Checker
Checks the model for errors and warnings. This tool is available in the Nastran and Altair OptiStruct solvers in NVH.
NVH Macros
Access pre-defined macros packaged with the NVH solution and also user defined macros.
Organize
Reorganize your database by copying or moving data (entities) among collectors or includes.
Orientation Review
Display/review and modify frequently used coordinate systems used in CAE analysis.
Part Replacement
Replace elements in an existing component/part (PSHELL) with new elements.
Position
Specify a new position for model entities.
Pretension Manager
Create and edit 1D and 3D pretension bolt loads and bolt sections for the Altair OptiStruct solver. This tool is only available when the Altair OptiStruct user profile is loaded.
Property Table
Displays properties and their associated attributes in an interactive table.
Quick Access
Quickly find and open the tools, panels and browsers that are available from the menu bar pull-downs or from the Utility browser.
Reflect
Reflect portions of a model about a plane, changing the selected portion into a mirror image of itself.
Renumber
Renumber entities.
Rotate
Rotate entities around an axis in space.
Scale
Increase or decrease an entity’s dimensions.
Set browser
Automate the grouping and display of model components through the entity set functionality.
Sets
Create, update and review named sets of entities.
Solver
Run an external program from within Engineering Solutions or assign and run a solver on selected analysis decks.
Summary Template
Obtain a summary of component element counts or element properties of the current model.
Tags
Assign names to entities.
Titles
Create, edit and move screen titles and entity tags.
Transformation Tool
Translate, scale, reflect or rotate elements with multiple numbers of copies including properties and loads attached to them.
Translate
Move entities in a single specified direction.
