The optistruct template generates Altair OptiStruct input decks.
The optistructlf template generates Altair OptiStruct input decks using the long format for CELAS, CONM2, FORCE, GRID, MAT1, MAT2, MAT8, MAT9, MOMENT, MPC, PBEAM, PBEAML, PCOMP, PCOMPG, PBARL, PROD and PSHELL bulk data entries.
DVGRID bulk data entries are written in long format with both templates.
All settings necessary to interface with Altair OptiStruct can be loaded by loading the Altair OptiStruct user profile.
The following summary templates are available for Altair OptiStruct:
components |
Summarizes the name, number, material, mass and number of elements for each component in the current database. |
constraints |
Summarizes the name, number, response, lower and upper bounds for each constraint in an optimization problem defined in the current database. |
ctr of gravity |
Calculates the center of gravity of the model. |
elements |
Summarizes the number of each element type in the current database. |
loads |
Summarizes the forces and moments applied to the current model. |
mom of inertia |
The mom_of_inertia template calculates the moments of inertia of the model. |
errorcheck |
Summarizes the model errors. |
responses |
Summarizes the name and type of responses in an optimization problem defined in the current database. |
Altair OptiStruct Interface
