Engineering Solutions
Problem Diagnostic and Study Capabilities
Innovative problem diagnostic and study capabilities:
Innovative approach for serving results based on physical relationships
A full set of integrated post-processing utilities
oIntegrated Diagnostics
oModal/Panel Participation from both system and CMS SE component modes
oGrid Participation
oEnergy Distribution
oTransfer Path Analysis
oDesign Sensitivity Analysis
oOrder Analysis
oModal FRF
oModel Correlation
oRadiated Sound
oMultiple Sample Analysis
oGlobal Modes
Response study: Investigate effects of varying modal, grid participation, transfer function, force, and so on.
Enables engineers to obtain a full understanding of physical root causes by leveraging mathematical cause-effect relationships and identifying sensitive parameters through quick what if studies.
In the end, NVH Director significantly reduces physical testing by running many iterations in CAE simulation and improves the value of testing by helping the engineer learn more from simulation.
