Engineering Solutions
Part Info
Part Info
This is the first topic This is the last topic No expanding text in this topic
Part Info
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Part Info macro summarizes a part’s statistics in a dialog.
1.To start the macro, click Part Info on the Utility Menu.
2.Click component on the main menu area to select a component or click a component in the graphics area to select it.
3.Click proceed.
The Part Information dialog appears, which lists the part ID, name, thickness, and material type.
4.To view additional statistics about the part, click the More Details tab.
5.To display statistics for a different part, select the part in the graphics area or the components selector and click proceed again.
Tip:Click the middle mouse button instead of the proceed button to quickly select components.
See Also:
LS-DYNA Utility Menu
