Engineering Solutions
Dynamic Reduction Techniques
A big challenge in full vehicle NVH simulation is handling large size finite element models. One approach to minimize full vehicle run time is to reduce the component finite element models to modal dynamic representations with much fewer degrees of freedom. Component Modal Synthesis (CMS) superelement is the most commonly used approach for modal reductions.
Altair HyperWorks CMS superelement capabilities:
Structure SE
Combined Fluid-Structural SE
Acoustic Cavity is included in the SE
DMIG of reduced matrices:
Stiffness
Mass
Structural Damping
Viscous Damping
Modal Area Coupling
Features:
Reduction of simulation time
Single H3D file implementation
Can have free-free, fixed or mixed attachments
Free-free attachment can be independent DOFs
Can recover panel and grid participation
Model definition is a part of the H3D file
Interior response recovery does not require MPCs
To keep primary structures confidential. Only matrices are delivered to supplier.
Can be used during optimization
See Also:
NVH Application
