Engineering Solutions
Modifying Auto Contact Entities
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
Right-clicking on an item in the Auto Contact browser displays a context sensitive menu which offers options for modifying the surfaces and contact pairs.
Rename
Rename an existing entry.
Delete
Delete items from the browser.
Swap Master - Slave
Allows you to switch the surfaces identified as master and slave. When selected, you will see the surfaces flip from the master/slave positions in the browser.
Select multiple entities by using the CRTL and Shift keys when clicking on entities.
Swap CP - Tie
Allows you to change the type of interface created. Because a surface interaction is required for Contact Pair but not for Tie, any surface interaction identified earlier will be lost upon a swamp from CP to TIE. (If you switch back from TIE to CP, the surface interaction will not be retained.)
Edit Faces
Allows you to manually edit the faces of the surfaces. This opens the Elements Selection panel where you can select and deselect the elements to include on the face of the surface.
Add by Adjacent
Adds adjacent elements to the selected surface.
Add by Face
Adds all elements to a selected surface, until the feature angle exceeds the value (the feature angle can by set by clicking the Options icon).
Accept All/None
Automatically accept or reject all items in the Auto Contact browser.
Reverse
Reverses the current selections in the Accept column.
Expand All/ Collapse
Expands or collapses folders in the Auto Contact browser.
See Also:
Auto Contact
To Set Up an Auto Contact Run
