Engineering Solutions
Mesh Menu
Mesh Menu
Mesh Menu
Aerospace has the following meshing capabilities:
Acoustic Cavity Mesh
Create a fluid volume mesh for the open-air volumes of an enclosed compartment, such as the passenger compartment of a vehicle.
Automesh
Create meshes or re-mesh existing meshing interactively or automatically on surfaces or groups of elements.
Bars
Create, review or update bar2 or bar3 elements.
Boolean Operation
Connect intersecting 2D elements. This tool works for triangular as well as quadrilateral elements.
Coarsen Mesh
Simplify the mesh by combining many small elements into a smaller number of larger ones.
Comparison Tool
Perform a model-based CAD-CAD, CAD-FE or FE-FE comparison between two models, or two selections of entities. You can also use this tool to find and report on geometrical/shape differences.
Create a 2D Element
Hand build, combine, split or modify elements.
Drag
Create a surface and/or mesh by dragging a series of nodes or lines, or to create elements by dragging selected elements.
Element Offset
Create and modify elements by offsetting from a mesh of plate or shell elements.
EM Lattice Mesh
Generate an axis-parallel mesh for 2D and 1D geometry input.
Fuse
Connect close proximity, overlapping, and intersecting parts.
Gaps
Create gap elements.
Hole Detection
Enables you to locate and define many, or all, holes in a model and add those holes as geometry to a new component or the current one.
Hole/Gap Fill
Mesh holes, gaps, and patches.
Line Drag
Create a two or three dimensional surface and/or mesh or elements by dragging nodes, lines, or elements along another line.
Line Mesh
Create a chain of one dimensional elements such as beams along a line.
Linear 1D
Create one dimensional elements.
Linear 3D
Create solid elements between two groups of plate elements.
Masses
Create mass elements.
Mesh Controls
Define one model specific mesh setting, as well as an unlimited number of local mesh settings.
Midmesh Thickness
Calculate the thickness of a mid-mesh from the solid geometry.
Nodes
Create nodes using a wide variety of methods.
Periodic Mesh
Generate a grid containing rotational and/or translational symmetric boundaries, for example rotating machinery.
Quality Index
Calculates a single value to represent the quality of the displayed shell (2D) model.
Quality Index Calculations
The Quality Index value is a function of twelve criteria with user-defined weight factors.
Quality Report
Creates an HTML mesh quality report.
RBE3
Create, review and update RBE3 elements.
Refine by Pattern
Create a regular orthogonal mesh
Rigids
Create rigid or rigid link elements.
Rods
Create rod elements.
Ruled
Create surfaces and/or meshes of plate elements from nodes, lines and/or line segments, in any combination.
Shrink Wrap Mesh
Generate an enclosed volume or solid mesh and is typically used to approximate and simplify an existing mode.
Skin
Create a skin surface and/or mesh from a set of lines.
Solid Map Mesh
Create a mesh of solid elements in a solid geometric volume.
Spin
Create a surface and/or mesh or elements by spinning a series of nodes, a line or lines, or a group of elements about a vector to create a circular structure.
Spline
Create a shell mesh and/or surface.
Springs
Create spring elements.
TetraMesh
Fill an enclosed volume with first or second order tetrahedral elements.
TetraMesh Process
Create tetra-meshes efficiently and effectively.
Voxel Mesh
Fills an enclose volume with voxels (hexas) of a predefined size. This type of mesh is only useful in topology optimization. It does not give meaningful results in a stress analysis.
