Engineering Solutions
Load Step: CLOAD: Define Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Define tab allows you to define *CLOAD (force or moment) cards on individual nodes or geometry (points).  You can also define the *CLOAD on node sets.
You can define CLOAD-Force/Moment on nodes/geometry or on node sets.  For Define CLOAD-Force/Moment on:, the following options are available:
Nodes or geometry
Node sets
The layout of the Define tab changes based on your selection.
See Also:
Load Step: CLOAD
