The Solver Options button opens a dialog with the different options available. The contents of the dialog vary according to the user profile you have selected:
The dialog presents options that allows you to determine whether to read these keywords from the solver deck into Engineering Solutions.
By default they are automatically read for for Engineering Solutions.
When importing an FE model and the By HM Comment option is selected but no HM comment cards exist, Nastran users can specify a ratio to be considered when importing Engineering Solutions entities. On import, Engineering Solutions will calculate the ratio of the number of elements to the number of properties.
• | If the calculated ratio is less than the specified ratio, all the elements are put into one component. |
• | If the calculated ratio is greater than the specified ratio, one component is created for each property. |
When importing an FE model and the By HM Comment option is selected but no HM comment cards exist, Altair OptiStruct users can specify a ratio to be considered when importing Engineering Solutions entities. On import, Engineering Solutions will calculate the ratio of the number of elements to the number of properties.
See Also:
Importing an FE Model
