HMASSOC – Used to associate an existing node to an existing surface.
HMASSOC node_id surf_id index
Altair HyperMesh Comments
This comment is used to associate an existing node to an existing surface. This allows nodes to be selected by surface, or moved along the surface.
node_id
The ID of the node to be associated.
surf_id
The surface to which the node will be attached.
index
The position that the node holds in the order of the surface.
