Engineering Solutions
Find Connectivity
Find Connectivity
Previous topic Next topic Expand/collapse all hidden text
Find Connectivity
Use the Find Connectivity tool to check the connectivity between two or more components. Certain types of connections can be included or excluded while checking for connectivity.
The Find Connectivity is only available in the LS-DYNA and Altair Radioss user profiles.
1.Open the Find Connectivity browser, from the menu bar, by clicking Tools > Find Connectivity.
2.Invoke the Find Connectivity controller by right-clicking in the browser and selecting Find Connectivity from the context menu.
find_connectivity_invoke_controller
3.In the Find Connectivity controller, enable the type(s) of connectivity to include in the check.
By default, all types of connectivity are enabled by except Connectors.
find_connectivity_checks
4.Using the Select Entities selector, select two or more components to check the connectivity between.
Connectivity check works on all the selected components regardless of its display state. Connectivity due to mass elements are completely excluded when checking connectivity.
find_connectivity_select_components
5.Click Check. Results are displayed in the browser.
If two or more parts are connected, the number of connected parts are displayed in the browser. Expand the folders to see individual components. If the parts are free, the free part is displayed separately.
find_connectivity_check_results
Connectivity Types
hmtoggle_arrow1Altair Radioss
Physical connectivity
Checks for node to node connectivity (for 1D, 2D and 3D).
RBE2
Checks for RBE2 connectivity.
Rigids
Checks for RBODY connectivity.
Interface2
Checks for contacts with INTER/TYPE2.
Connectors
Checks for FE realized connections with connectors.
Rigid Links
Checks for RLINK connectivity.
RBE3
Checks for RBE32 connectivity.
Joints
Checks for CYLJOINT connectivity.
hmtoggle_arrow1LS-DYNA
Constrained Extra Nodes
Checks for connections using constrained extra nodes and extra noded joints.
*CONSTRAINED_EXTRA_NODES
Constrained Rigid Bodies
Checks for connections using constrained rigid bodies.
*CONSTRAINED_RIGID_BODIES
Constrained Groups
*CONSTRAINED_TIE-BREAK
*CONSTRAINED_TIED_NODES_FAILURE
Contact Groups
*CONTACT_SPOTWELD
NodesToSurface (only following types)
*CONTACT_TIED_NODES_TO_SURFACE
*CONTACT_TIEBREAK_NODES_TO_SURFACE
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE
SurfaceToSurface (only following types)
*CONTACT_TIEBREAK_SURFACE_TO_SURFACE
*CONTACT_TIED_SURFACE_TO_SURFACE
SlidingOnly
*CONTACT_SLIDING_ONLY
Connectors
Rigid Links
*CONSTRAINED_NODAL_RIGID_BODY
*CONSTRAINED_NODE_SET_ID
*CONSTRAINED_GENERALIZED_WELD
*CONSTRAINED_SHELL_TO_SOLID
Welds
*CONSTRAINED_SPOTWELD
RBE3
*CONSTRAINED_INTERPOLATION
Joints
Checks for connections with Joints
Slipring and Retractor
Checks for connections with sliprings and Retractor
*ELEMENT_SEATBELT_SLIPRING
*ELEMENT_SEATBELT_RETRACTOR
See Also:
Basic Browser Opeartions
