Engineering Solutions
Customizing Views of the Material Table
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Material Table initially lists all existing materials, but you can sort and filter the list to more easily identify materials that you want to work with. Each of the columns in the table can be used to sort the list. Click the column heading to sort by that characteristic, such as ID number or material type. To view only materials of a particular type, select that type in the Material type drop-down at the top of the window. For example, if you want to identify materials that are not used so you can delete them, you can click the Comp used column heading to quickly group together all materials that contain the value "No", which indicates that none of the components use the material.
Note:To view all material properties in the table, select a material type from the drop-down. When all material types are shown in the table, only the RHO (density), E (Young's modulus), and Nu (Poisson's ratio) properties appear. However, when a particular material type is displayed, all the relevant properties for that material type also appear in the table, as shown in the image below.
material_table_02
The Material Table also enables you to view the model's components based on the material used. These options are available by selecting Display from the menu that appears when you right-click anywhere in the table. Options include:
viewing only the selected materials
hiding the selected materials
viewing all or none of the materials
adding the selected materials to the current display
reversing the current display option.
Once you make your selection, the corresponding components appear or become hidden in the graphics area.
See Also:
Creating, Editing, and Loading Materials
Managing Materials
LS-DYNA Material Table
