Engineering Solutions
Create Part
Create Part
This is the first topic This is the last topic No expanding text in this topic
Create Part
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Create Part macro enables you to create components on-the-fly. It can be accessed by clicking Create Part on the Utility Menu when the LS-DYNA user profile is loaded.
Type a name for the new component in the Part name field and select a color by clicking the adjacent color icon.
Select a section in the Section field by choosing Create New (create a new section), Same As (create a new section based on an existing section), or Model… (select an existing section) from the selection menu.
Select a material for the component in the Material field by the same method as described above for the Section field.
Click Create>> to either create or create and edit the card.
See Also:
LS-DYNA Utility Menu
