Aerospace has the following boundary condition tools:
Auto-Contact
Quickly and easily create one or more contact interfaces at once between several parts of your model. This tool is only available in the Aerospace user profile when the Altair OptiStruct and Nastran solvers are loaded. |
Select the entities that are viewed in the card image subpanel. |
Place constraints or enforced displacements on a model. |
Create and modify contactsurf entities. |
Create contour plots of applied loads and boundary conditions contained within load collectors. |
Delete data from a model database, preview and delete empty collectors and preview and delete unused property collectors, material collectors, or curves. |
Create, review and update equations. |
Apply concentrated fluxes to your model. |
Create concentrated forces. |
Create and modify interfaces. |
Allows total loads (forces and moments) to be applied in a distributed manner on nodes even though the load is applied on geometry lines or set of nodes forming ordered edges. |
Map loads or boundary conditions from geometrical entities (loads on geometry) to the associated FE mesh entities (loads on mesh). |
Creates a summary of the loads (node-based forces or moments and element-based pressures) applied to a model. |
Create concentrated moments. |
Reorganize your database by copying or moving data (entities) among collectors or includes. |
Create concentrated pressures. |
Renumber entities. |
Create rectangular, cylindrical and spherical coordinate systems. |
Create temperature constraints. |
